Alpine IVA-D300R
Ja sam nasao samo ovo, ako pomaze:
Blackout Mode On and Off
When Blackout mode is turned on, the display will turn off to reduce
power consumption.
This additional power enhances the sound quality.
Touch [V.SEL] on the main source screen.
The VISUAL selection screen is displayed.
2
Touch [OFF].
The backlit-display portion goes out.
3
Touch [OFF] again to cancel the display backlight.
• If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
avi je samo nosilac, a koji codec je koriscen za kompresovanje u avi je problem.
Uredjaj ga sad ne cita, a ti uzmes taj avi i rekompresujes sa wm9 codec ili divx ili neki treci koji taj uredjaj podrzava i opet imas avi ali ga sada cita.Fifteen years of research he'd filed from one planet alone and they'd cut it to two words. "Mostly Harmless."
11.04. 0:12 #2
