Vrlo zanimljiv dizajn mixera, nadam se da ce se uskoro ovako nesto pojaviti i kod nas da probamo...
Benefits of Fitting a VPM mixer
More power
More performance under load
Less restriction - due to its unique variable venturi
Better fuel economy
No hesitation
No flat spots
Mixer has a 17/19 mm gas inlet fitting
Available to fit engines from 1000 to 7000 cc
Can be fitted internally inside or in between hoses, etc.
Mixer is a male to male fitting available in the following sizes 72, 74, 76, 78 & 80 mm diameter
More power
Better fuel economy
No hesitation
No flat spots
