Kod motora koji je bio u autu originalno i kod motora koji je sad u autu
Oxygen sensor heater?
F23A5
This engine was used in the 1998-2002 Honda Accord DX in North America.
Specifications
* Bore × Stroke: 86.0 × 97.0 mm
* Displacement: 2254 cc
* Valve Configuration: SOHC, 16 valves
* Compression ratio: 8.8:1
* Max power: 135 hp (100 kW) @ 5500 rpm
* Max torque: 153 ft?lbf (206 Nm) @ 4500 rpm
F20A
This engine series was used in the 1989-1992 and 1993-1996 Honda Accords in Japan. The DOHC F20A was also derived from this engine (see below).
Specifications
* Bore × Stroke: 85.0 × 88.0 mm
* Displacement: 1997 cc
* Max output : 135 PS @ 5400 rpm (PGM-Fi), 110 PS @ 6000 rpm (PGM-carb)
* Max torque : 18.5 kgm @ 4300 rpm (PGM-Fi), 16.1 kgm @ 3800 rpm (PGM-carb)
* Fuel consumption (Japan Combined Cycle) : 9.6 km/l (PGM-Fi), 9.8 km/l (PGM-carb)
This engine also spawned many variants, according to market, but the specs remain largely similar
http://en.wikipedia.org/wiki/List_of_Ho ... 4-cylinderAtt mäta är att veta...to measure is to know...meriti je znati..
Po dosadanjem istrazivanju deluje da su motori koristili razlicite sisteme ubrizgavanja.. no, dodji sa podatcima koje sam trazio da se malo razlista sta je sta i odakle je kompatibilno.Att mäta är att veta...to measure is to know...meriti je znati..
cek, sad mi nije jasno..vi ste cupali stari motor, i ubacili novi druge generacije bez izmjene ECU-a? hm. pa ak ste to napravili....inace se stravlja motor+ecu+za svaki slucaj paralelna instalacija. getriba, po potrebi..."Your eyes look a little red son... have you been hitting VTEC??"
@Boost
U prelude se pakovao h22,i h23, a za evropu su Englezi pakovali F20a iz accorda kao najslabiju verziju
znaci pre je bio h23 dohc 16v 87.0 × 95.0
a ubacen je f20a sohc 16v 85.0 × 88.0
Ako je stvarno tako kao sto kaze speedster,da je covek samo ubacio motor i reko vozi a posle se cudio kako ne moze da nasteluje paljenje......nemam reci!
jbga, sad ti ostaje jedino da provjeris ima li u hrvatskoj netko takav ecu. ili u srbiji. ja ti imam ecu za d16a8 tak da ti taj ne pashe"Your eyes look a little red son... have you been hitting VTEC??"
Ajde vi koji sye u toku sa Evropa modelima, pogledajte da li ta 2 motora koriste istu generaciju ECUa, dakle da li je ozichenje kompatibilno, za ECU j najmanji problem, dajte neki auto koji je imao ECU koji je potreban, ali podvlacim ako je intalacija pin out layer isti.
Naci cu ja ECU , da se pomogne coveku
