Originally posted by duxducis
After market ECU; konverzija na EFi ubrizgavanje
Boost,Originally posted by BOOSTNenade >> 4 630cc injektora daju sda Nirom na SAAB motoru 530 KS.
Motor ide na ivici siromasne smese, masti samo po potrebi prema temp izduva.
govoris o 630cc na 3Bara ili 630cc na pritisku koji je u tom konkretnom motoru?
Alex treba da odredi i DC dizne jel' od DC i BSFC zavisi koliko ce realno goriva da se ubrizgava.
Alex,
Koliki je pritisak goriva kod tebe?Boost or bust...
Ako bude relevantno bice 3,8 bara osnovni pritisak.
DC injektora sa mAX 90
SAAB je teran sa Baznim pritiskom 3,8 bara
Temperatura izduva 970 CAtt mäta är att veta...to measure is to know...meriti je znati..
Mislim da cemo svi razumeti
BSFC is the measure of how effectively an engine takes advantage of the fuel in its combustion chamber. SFC is usually measured in lb/hr/HP or cc/min/HP, and traditionally good values are 0.40 lb/hr/HP (4.2 cc/min/HP) or lower; newer engines with better airflow numbers, and fuel and spark management have lower numbers. As the number gets bigger, the engine is using more fuel to make less power, so you want this number as small as possible. (Turbo and supercharged engines are notorious fuel gulpers and often have SFC numbers of 0.55-0.60 lb/hr/HP.) Note that improvements in SFC affect power output in a direct linear proportion. If at a given flow and AFR you can improve SFC from 0.50 to 0.49, you have increased power by 2%.
SFC is a function of many factors, not the least of which is static compression ratio. Increasing CR increases thermal efficiency, which directly affects SFC. Lowering the rod to stroke ratio can improve SFC to a point due to combustion pressure being applied when the crankshaft at a more advantageous angle (but it also induces greater frictional losses from piston side forces). Use of cast iron or thermal barrier coated cylinder heads, instead of bare aluminum, keeps heat in the chamber and lowers SFC. Likewise, use of thermal barrier coatings on valve faces and pistons drops SFC. Reducing internal engine friction and pumping losses improves SFC, so port your lubrication and cooling systems.
Combustion chamber design has a huge impact on SFC. A chamber with stratified charge (one where AFR varies at different places in the chamber, typically rich near the plug, but lean away from it) or lots of swirl usually was designed to improve SFC. Small, compact chambers which cause the charge to burn rapidly often have a lower (better) SFC than extended, flat ones. Placement of the spark plug in the chamber is important: a central location allows for a faster more efficient burn than an off center one.
Zato i kazem da je uvek bolje izmeriti konkretan BSFC za dani motor nego posle davati vise novca.Boost or bust...
Onda moze da se izracuna (otprilike) da ce sa diznom od 545-550cc/min na 3 Bara BSFC 0,57 i DC 90% da gura oko 840cc/min. Ako na ovo dodas jos pritisak od 3,8 bara umesto 3 Bara bice preko 900cc/minOriginally posted by BOOSTAko bude relevantno bice 3,8 bara osnovni pritisak.
Moje su dizne sada 273cc/min na 3 bara, auto pravi 4 bara na liniji i DC mi je 95% sve ovo max do 300ks za 6 cilindricni motor.Boost or bust...
Hvala za objasnjenje sta je BSFC
,ali sad sam tacno izgubljen u tim vasim formulama
05' GSX-R 750(yosh,K&N,PCIII...)
03' inf. G35-Greddy TT narucen
95' M3 turbo-Prodat
97' M3-4 vrata automatik
95 M3 PTG widebody(3.2 masina +vortech supercharger)
Pa nece....vec je receno da ce raditi najverovatnije na 3,8.
Mislim ispod 3.5 nece se ici sigurno.
I da...da napravi rail kod strugara po tvom uzorku....nece da moze.
Dobro, eto neka je 3.5, nije 5 ili 6, koliko vec rece da mu radi sad.
A za rail, pa hoce hoce. Nisi video rail koji koristim
Nema nikakve bre mudrosti, najobicnija cevka koja se nastavlja jedna u drugu, zasto bi bio problem da se par takvih nastavi i prilagodi bokseru? Na to mislis? Pa zato i kazem, to je otprilike najmanji problem koji moze da ima u celoj prici. Ako je jos i FPR integrisan na pumpi, jos lakse, nema return line.
